http://imatouch.ru/forum/
ISP side to notice the disconnection and reset?
http://imatouch.ru/forum/viewtopic.php?f=11&t=715
Страница 1 из 1
Автор:  spadekevin [ 08 авг 2018, 18:17 ]
Заголовок сообщения:  ISP side to notice the disconnection and reset?
Hello,
First, the router has to be unplugged while the modem boots or it doesn't pull an IP (via DHCP). I know this matches conventional instructions (plug in the modem, then plug in the router), but this is the first cable modem I've ever encountered where it actually matters.
Second, I can't simply power cycle the modem. I have to leave the modem unplugged for a solid two minutes or again it won't pull an IP. To me this seems like an awful long time for just residual data to clear from memory.
Can I fix likely fix this on my side by replacing my equipment - fixed defined as gear just boots and works - or is the lengthy power down a matter of waiting for something on the ISP side to notice the disconnection and reset?
Please help.
I didn't find the right solution from the internet.
References:
https://arstechnica.com/civis/viewtopic ... &t=1148659
Talent Acquisition Service Video
Thank you.
Страница 1 из 1 Часовой пояс: UTC + 3 часа
http://www.phpbb.com/
